Displays traffic counts for each QoS profile on the specified stacking ports.
| stack_port_list | Specifies one or more stacking ports. |
| no-refresh | Specifies a static snapshot of data instead of the default dynamic display. |
| refresh | Specifies a continuous refresh of output. |
| port-number | Displays port number instead of display string in the output of the command. |
Displays packet counts in real-time.
If you do not specify a port number or range of ports, traffic counts appear for all ports.
The bottom line in the real-time display shows keys that you can press to change the display. For example, the space bar changes the display from QoS traffic counts in either packets or bytes.
If you specify the no-refresh option, you see a snapshot of the data at the time you issued the command.
# show ports stack-ports 1:1-1:2 qosmonitor Qos Monitor Req Summary Fri Apr 21 10:58:23 2017 Port QP1 QP2 QP3 QP4 QP5 QP6 QP7 QP8 Pkt Pkt Pkt Pkt Pkt Pkt Pkt Pkt Xmts Xmts Xmts Xmts Xmts Xmts Xmts Xmts ================================================================================ 1:1 0 0 0 0 0 0 0 0 1:2 0 0 0 0 0 0 0 0 ================================================================================ > indicates Port Display Name truncated past 8 characters Spacebar->Toggle screen 0->Clear counters U->Page up D->Page down ESC->exit
This command was first available in ExtremeXOS 22.3.
